husqvarna 55 chain saw
/ husqvarna 55 chain saw #1
mechanic
missouri
Won't start. When I use the spark tester I can see spark as I pull the rope but when I stick the spark plug in I don't see anything. The plug gets wet when I try to start but no spark to the plug. That same plug will run my weed eater. What I don't understand is why does the spark tester show spark but the plug shows nothing. I'm almost ready to buy a coil and give it a try Any ideas?
/ husqvarna 55 chain saw #2
The coil and wire shouldn’t have more than a few ohms of resistance. Test that before you get a new coil. Also verify the on/off switch is making good contact- that’s one of the more common “no spark” causes.
/ husqvarna 55 chain saw #3
Are we sure that the flywheel hasn't slipped and throwing the timing off. And have you tried a new plug in the saw. They can do weird things sometimes. Is there a possibility that the carb is dumping too much fuel in causing a flooding issue.
/ husqvarna 55 chain saw #4
Actually, on a chainsaw you want to make sure the on/off switch is NOT making contact when it is in the run position. The switch needs to be OPEN for the saw to run, closing the switch basically grounds the sparkplug out, preventing ignition.
/ husqvarna 55 chain saw #5
Actually, on a chainsaw you want to make sure the on/off switch is NOT making good contact. The switch needs to be OPEN for the saw to run, closing the switch basically grounds the sparkplug out, preventing ignition.
Agreed, just disconnect the wire to the switch and make sure it does not short to ground and test for spark.
Also make sure the exhaust muffler is tight (nothing to do with no spark, just another problem these saws have)
/ husqvarna 55 chain saw #6
An electric switch, by design, is opening and closing a set of contacts. So testing the switch function and wiring would be a part of my diagnosis before ordering a new coil.
/ husqvarna 55 chain saw #7
most coils can be tested at quality repair shops...bad coils may still put out a spark (sometimes) but may not necessarily be at the right time etc...
There have been other threads where similar issues with coils have been discussed...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
iDrive TDS-2010H...
2016 Volvo XC60 SUV (A61574)
2016 Volvo XC60...
Beverage Truck Body (A61573)
Beverage Truck...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59912)
2020 KENWORTH T680...
