Husqvarna 450e Bar Oil Leaking at case seam
   / Husqvarna 450e Bar Oil Leaking at case seam #1
Avondale
Platinum Member
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
Has anyone experienced a leak at the seam of the bar oil tank? I have tightened all the bolts I can find. Thanks in advance for whatever help available.
   / Husqvarna 450e Bar Oil Leaking at case seam #2
I don't know exactly how it is designed but I know that when you over-tighten the bolts it will deform the casting and make the leakage worse. What you need to do is either replace the gasket (if there is one) or use polymer sealant (like is used on engine oil pan). Before you do it you might check flatness of the removable part of the oil tank.
Thanks. The tank is plastic.
   / Husqvarna 450e Bar Oil Leaking at case seam #4
Thinking it was all plastic tank and crankcase. No bolts to tighten like a split metal crankcase. I use Seal-All for plastic tank seams.
shopping
I have seen this before in the shops, wondering if I would ever get the saw apart afterward, (should I ever need to).
   / Husqvarna 450e Bar Oil Leaking at case seam #6
This is your crankcase and it dont come apart. it is all plastic.
Chainsaw Repair http://chainsawrepair.createaforum.com/index.php
I had a 029 come in with cracked oil tank. Choice was replace crankcase or redneck it with the sealer. Been 2 years and still sealed and out there cutting firewood.
Thanks, looks like the obvious choice
   / Husqvarna 450e Bar Oil Leaking at case seam #8
shopping
I have used this on many oil tanks as well as fuel tanks. I might add that proper application is critical.
I always drain a fuel tank and flush with straight gas. Set in sun until completely dry. If possible, I have a special scraper with small head and long handle that I try to rough up the INSIDE surface. I always apply to inside, if possible.
Clean well with a rag saturated with lacquer thinner, wrapped around a stick and allow that to dry before applying sealer.
Application is just as much trouble as cleaning. I just apply with chopstick--LOL.
I have never had a failure--yet.
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
Skidloader Forks (A50774)
Skidloader Forks...
2014 Ford F-250 Service Truck (A50323)
2014 Ford F-250...
Pallet Fees (A50774)
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
