Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
Are you trying to split bigger/harder wood than it was designed for, or simply trying to make it cycle faster? I dont think you get very much of either as, like J_J says, they are sold adjusted pretty much to max already.
no not really just a wondering. how would you check the pressure. ?
how would you know what the pressure is suppose to be set at. ?
is the adj. on the valve or the pump. ?
To check and adjust pressure a gauge will need to be installed between the pump and control valve. The relief in the control valve can then be adjusted to increase pressure. If the relief is set too high the engine will stall or if the engine produces more hp. then intended for that particular size pump the relief pressure can be increased to the point at which the pump breaks.
Max. psi setting depends on the pressure ratings of the various system components. The cylinder will typically have the lowest rating generally 2500-3000 psi working pressure.
The advertised tonnage of most retail splitters is based on pressure spikes not working pressure.
Any gauge you want that is at least 3000psi rated.
But if you plan on tee-ing in, make SURE you get hydraulic fittings. NOT just plumbing fittings from your local box store. Go to a hydraulic shop, or order from a hydraulic sales place online.
