Husk Rancher 455
   / Husk Rancher 455 #1
Lloyd_E
Veteran Member
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
Bought a new 455 a month ago. Now putting it through the trial period. This saw with the 18 inch bar is amazing for its price point($399.95). I moved up from a stihl 025 - have 2. I am chunking jack pine up to 32-36 inches. I chunked 11-13 cords of wood over a two day period. It never powered down and worked great. Just starting to split it now. The challenge is getting the large chunks on the splitter. I used a ramp the other day which worked ok. The splitter is home made and we have to do some maintenance this winter. My buddy and I built it about 7 years ago... we have run about 60 cord through it so far. I suggested to him the other day that we rebuild it so that it can tilt vertically...
The stihls will be used for limbing etc. There are both goods saws but I am pushing the limit in terms of being able to chunk large stuff - 28 inches+.
Later...
   / Husk Rancher 455 #2
I've had my 455 for a few years now, no problems at all, very reliable for me.
   / Husk Rancher 455
CT,
Glad to hear...
I estimated roughly between 10-12 cords of wood. I hauled home a full 13'x6'x2' load on my landscape trailer which is about 1.25 cords. Barely put a dent in the pile. So I am thinking it might be close to 15-18 cords... The picture shows about a third of the wood pile. It extends another 15 to 20 feet to the left of frame.
   / Husk Rancher 455 #4
Another :thumbsup: for the 455. All round good saw, lightweight and easier than my big Stihl.
   / Husk Rancher 455
Photo didn't load...
   / Husk Rancher 455 #6
I have a Husky 455 Rancher also it is an awesome machine with a 20" bar and it likes to work a lot harder than i do. I did find that they have two differeent air filters for it, a summer one and a winter one. The summer one will work in the winter but it takes longer for it to warm up and power properly however the winter one will never run right in the summer or above 50-60 degrees out. Just an fyi if anyone has a won't start or stay running problem.
   / Husk Rancher 455 #7
The winter filters I have for stihl and husky saws are mesh screen which allow the saw to breath better.
If your 455 uses the same type winter filter and wont run right in summer with it you need a carb tuning. JMO.
I have used a winter filter in summer conditions depending on wood being cut.
   / Husk Rancher 455 #8
What I do with stuff to big to lift is either split it with a maul if the grain is straight, or just rip the piece in two with the saw. Going parallel to the grain is quite fast and I'd rather wear out my saw than my back! I did 300+lb rounds of Ash this way, just ripped the ugly hard to split parts, and split the rest with the maul.
   / Husk Rancher 455 #9
Affix a sheet of plywood the size you want to your forks. if you wish, you can stand and screw in some two-by's on edge to act as borders. Roll your large rounds onto the plywood. Sidle up to your splitter on the opposite side you stand to split and use the plywood as a staging table to roll the rounds onto the beam of the splitter. If you are close enough, the plywood can also act as a splitter table if you push the large halves onto it to await further splitting. It would be helpful to use either a log hook or picaroon to help drag the rounds to you more easily off the "table".
New Holland B95 Backhoe (A50490)
New Holland B95...
2018 CAT 320GC Excavator (A47384)
2018 CAT 320GC...
International 56 2-Row Pull Cornplanter (A50774)
International 56...
TEST YOUR BID BUTTON! (A51243)
TEST YOUR BID...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2004 Mercedes E320 (A50324)
2004 Mercedes E320...
