Husco 5000 question
   / Husco 5000 question #1
Mwhydro
I have a home made log splitter from my grandfather he gave me a husco 5000 valve to put on it. I hook up to the inlet and outlet but it won't bypass in neutral not quite sure why any help would be great.
   / Husco 5000 question #2
It most likely a closed center valve....You can probably get parts to rebuild it...might even be as easy as removing a center plug by the tank port....I'll look up Husco and take a look at it....
5 min later....
Yes...you can use the valve after some minor modifications.....
It seems like you need to remove a Closed Center plug....
Read page 17-19 in this Husco 5000 pdf file
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2025 CFG Industrial MX12R (A50123)
2025 CFG...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2016 GMC SIERRA 3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
2014 Freightliner M2 106 Ambulance (A51692)
2014 Freightliner...
Trojan 5T-45 36in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 5T-45 36in...
