Seeders hurry primary seeder ?
   / hurry primary seeder ? #1
kch
Bronze Member
attention landscapers.......or anyone else......I have over one acre to seed for a lawn. If i rent a primary seeder made by landpride do you have to still use straw or is it just as good to just use a spreader and throw the seed out on the ground and cover it with straw? also can you use an overseeder for a new lawn? also what is the best way to remove all the weeds and grass? the house is in the middle of a corn field and we are talking industrial size weeds. will a box scaper handle it and what about removing thick established grass.....a box scaper??? thanks
   / hurry primary seeder ? #2
U need to KILL all the weeds first.
2,4D will kill broad leaves
Round up (takes about 3 weeks to work) or some other burn down herbicide
to kill everything.
Use ripper teeth on box blade or disk to loosen soil.
I would use tiller to chop it all up (rock hound or preparator on skid steer).
Then rake to get rocks or drag to level.
w/ fall coming u can seed then straw and water water water water.
I just put in 3 acre yard had to haul 500 ton fill dirt and 200 ton topsoil to get the owners happy.
600# seed
1000# starter fertilizer
200 bale straw
   / hurry primary seeder ? #3
Another idea, make friends w/ local farmer and see if can spray your
X corn field then take large disk (our 24' IH works good for this but 35D won't pull it)
and do the heavy work for u.
He could even drill the seed for u.
Then u can do the leveling and seeding.
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2025 CFG Industrial MX12R (A50123)
2025 CFG...
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
2020 Ottawa T2 Spotter Truck (A52384)
2020 Ottawa T2...
