Hunting a knock in ford 4000 engine
   / Hunting a knock in ford 4000 engine #1
somanytractors
atlanta, ga
several
I have a 4000 with a knock in it. I already put bearings in it before pulling the motor but it didn't seem to help much.
I haven't measured everything yet. I did get the pistons. 4.394 was the smallest measurement across. 4.386 parallel with wrist pin.
Bores are 4.401 - 4.404. Should it be bored, just new pistons, or should be ok?
I did notice that the gear to the oil pump bounces up and down a lot, like 1/2" or more. Is this normal or should something be holding it down?
I also noticed some play in the gear that goes between the crank, cam, and injection pump. The bushing looks good but there's no thrust washer. Should there be a thrust washer?
1992 Effer 7600 2S Knuckleboom (A49346)
1992 Effer 7600 2S...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A49346)
2016 Toro...
