Hub Seal Leak
   / Hub Seal Leak #1
wkpoor
Platinum Member
Amanda, OH
John Deere 5400, Farmall H, Farmall Cub, Allis Chalmers CA
I realize this is a trailer forum but since I don't belong to any truck forums I'm posting here.
I've got a GM coporate 14Bolt SRW axle that is leaking out the inner hub seal on the R/H side. I've been fighting it all year. I'm sure it was doing this since new but since I don't drive the truck very often and I didn't catch it till this yr. Got a friend with the same exact issue and his is a 93... only 50,000mi same as mine.
First time I had it apart I replaced the bearing too as I noticed the inner bearing race was cutting into the axle stub flange and I figured it was under torqued from the factory. Well 2 seals later its still leaking and the bearings are still cutting into the axle stub flange even with the recommended 52'lb torque. I tried setting the seal all the way in and that helped but didn't stop it. The L/H side showed same bearing wear so I replaced them and seal also. No leaks before and now. Problem is on the R/H side only for the leak. Both sides for bearing wear.
   / Hub Seal Leak #2
Have the axle checked for true, if it is out it can cause short seal life & bearing problems.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
1261 (A50490)
1261 (A50490)
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
