Hub bolt
   / Hub bolt #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
Guys, I'm having a tough time finding a missing hub bolt. This is the cross bolt used to snug the hub up against the axle shaft. It's the one with a spring on it. The problem is that the head of this bolt is a funky size. The bolt measures 1-1/2" long, 9/16" diameter, the head is 3/4" across. Anybody have one they're willing to sell? Yes, used is fine.
   / Hub bolt #2
"The problem is that the head of this bolt is a funky size."
Why is the head size critical? All that should matter is bolt length, diameter, and thread count. Assuming it's for a Yanmar, it should be metric, and you should have another one to use as a sample.
   / Hub bolt
Well, to change wheels I have 6 of these to loosen and tighten. Having to use two different wrenches for one bolt would drive me insane. It's the little things in life that pushes people over the edge...
   / Hub bolt #4
I believe you are referring to a lug bolt/with lock washer, I would think everybody, (Yanmar parts dealers), would have those.
   / Hub bolt #5
I used to have a couple laying around somewhere...I just can't think of what happened to them?? /forums/images/graemlins/grin.gif
If you strike out it's possible to turn down, file or grind off the head and weld on the correct size nut for replacement.
Mark
   / Hub bolt
Yea, I already bought a bolt, figuring I'd just grind the head down. But that's so hackish that I figured I'd try on the board as a last resort. I never thought to weld a nut on. That one has real possibility.
   / Hub bolt #7
You can get any bolt under the sun at this place.
I deal with many Japanese and European machines and we get all of our bolts from them.
You could probable replace all 12 for under 25$ plus shipping.
http://www.mcmaster.com/
Tom
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
Pallet of Misc Fabrication Steel (A52384)
Pallet of Misc...
2003 Ferris IS1000 52in Zero Turn Mower (A51691)
2003 Ferris IS1000...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
10" Shaver Post Driver (A52384)
10" Shaver Post...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
