Hst squeel from Hell
/ Hst squeel from Hell #1
Dude1234
Rk55
Had a question my rk 55 started making a squeel noise that is just the worst on the ears randomly if i use the auto button. I will be driving and whn i let off the accelerator it will continue to squeel. If i touch the pedal either forward or reverse the nosie will stop. The sound is different from the normal whining noise if you operate lets say in high gear.
If i opperate at high rpms i make the noise bearable but as soon as i throttle down when stopped you can hear it. It will even make the noise in the neutral position if i press the accelerator in reverse.
Tractor has 80 hours. Seemed to start after the 50 hour service. All fluids are spot on.
Any thoughts?
/ Hst squeel from Hell #2
often a sign of your pump failing or a clogging screen/filter
/ Hst squeel from Hell #3
Were the filters changed at 50 hour service? If yes are they OEM or aftermarket? Some models of tractors are sensitive on what filters are used.
What type of fluid was used to refill the transmission?
At 80 hrs is it still under warranty?
/ Hst squeel from Hell #4
TYM, which the RK is, I've heard from the best TYM pros on this forum, is quite sensitive to filters... They require a specific bypass, so aftermarket will be a crap shoot.
Which is why I used OEM
Thanks for the reply. All filters were changed at the 50 hour services. the big one is oem tym. the other was a filter next to the fuel tank is napa gold made by man which the oem was a man.
Correction* the sound is like a wooot or rooot noise that is in harmony. If i throttle up it goes away… i think…. I noticed if i stop on an incline the noise happens. Also noticed if i put the tractor in position 1 or 3 ,the botton on the dash that dictates how quickly it stops or rolls, that i could hear it wanted to do it but would immediately stop. I didnt play with it that much but its bizzare. I might just bite the bullet and through some new filter on maybe one of the two new filters are bad….
Question:
What screens? Is there other filters beside the two? I spoke two the machanic he said the transmission has a screen filter that a foot long that next to the hard line but i could not find anything on the part diagram. I think he may have been wrong…. Or confusing a different model.
Tractors still under warranty and the oil is the rk brand they recommend.
/ Hst squeel from Hell #6
For clarification:
Is the noise present when you are not moving?
Does it make noise if range selector is in neutral and you press either forward or reverse pedal?
Do you or your dealer have the equipment to check charge pressure? Reason for asking is I suspect your HST is electrohydraulic pilot controlled so fluctuating noise could possibly be caused by charge relief being slightly unstable under certain conditions.
Since under warranty the amount of work you do is your choice vs seeing if dealer will check things out.
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2014 NISSAN NV CARGO VAN (A59905)
2014 NISSAN NV...
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A60352)
2015 GMC 3500 HD...
