HST Question
/ HST Question #1
dillo99
Upstate NY
Kubota B7500
This is probably a silly question but I'll ask it anyway!
If you are driving the tractor (no loads) does the pedal down half way in high gear cause more transmission wear than the pedal all the way down in low gear? I am assuming that the HST is NOT like a clutch and therefore there is no additional transmission wear from 1/2 pedal. Right?
I have some bumpy spots on my trails and so I tend to travel in high gear but vary the pedal frequently to slow down over bumps. After doing this for quite a while I started to wonder if this was somehow causing more wear than if I just traveled in low gear and kept the pedal at full.
Thanks in advance for any insight!
Mike
/ HST Question #2
Mike
Makes no difference at all and under the circumstances you described you are doing no harm to the HST. It is not like a clutch. When you have the pedal only halfway down, it isn't slipping like riding a clutch pedal would create. That's why they describe it as infinite. The gear selection is after the HST and is used as a multiplier to increase torque to the rear axle.
/ HST Question #3
"does the pedal down half way in high gear cause more transmission wear than the pedal all the way down in low gear?" That is a superb question for which I can clearly state "I don't know." In a high gear, half speed position, the individual hydrostatic pump parts operate under a higher hydraulic pressure, but only half as often. Does the higher pressure, lower number of cycles reduce overall wear? I will guess that it does reduce wear, but my thinking is indirect. On tests reported in the Society of Automotive Engineers technical papers, the Detroit Diesel company had a technical paper that showed lower engine cylinder wear at a given power output at lower RPM operation. However, when RPM was lowered below a certain level, cylinder wear increased. Without full load, I suspect that pump pressures are moderate even in high gear. Hydrostatic pumps and diesel engines have in common the fact that both contain cylinders and pistons that operate under pressure and incur wear over time. The many other differences makes it risky to draw the inferences that I present above.
JOHN DEERE 325G SKID STEER (A64279)
JOHN DEERE 325G...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
2013 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A64279)
2013 KUBOTA KX71-3...
2015 Volvo L30GS (A62180)
2015 Volvo L30GS...
KBH Tender (A63688)
KBH Tender (A63688)
PALLET OF (73) 4.80/4.00-8 GOLF CARTS TIRES (A64281)
PALLET OF (73)...
