HST pedal relearn
   / HST pedal relearn #1
mikegatherall
Mahindra 5010 cab hst
Had cab off Mahindra 5010 to repaint including peddle bracket assembly...all back together but no reverse ...when keyed on the F light is illuminated and I have to move both pedals slightly to register N so it will start ...
When idling, F light remains illuminated but cannot get R to engage ....
Each peddle is attached to a potentiometer to control pedle position signal ....I have a pair of Volvo marine engines which use similar configuation to establish fwd/ reverse and speed and there is a proceedure for relearning the control head if needed .... I.e.key on holding a button then moving lever through various positions and pressing a button at each stage so system learns the position and then its is stored in the ecu....
Is here a similar proceedure for the HST transmissions on these tractors?
   / HST pedal relearn
Sorted ....removed peddle assembly and adjusted potentiometer housing - mount allows for about 10 degrees of movement ...all good - now starts in neutral and fwd and rev working as intended....
2015 Ford E-350 Passenger Bus (A50323)
2015 Ford E-350...
TRUBILT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
TRUBILT SKID STEER...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
Wolverine Quick Attach 72" Bucket (A50514)
Wolverine Quick...
2007 Polaris Ranger (A50514)
2007 Polaris...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
