HST Pedal on ck20 sticking! AHHHHHHHHHH!
   / HST Pedal on ck20 sticking! AHHHHHHHHHH! #1
Agentiron
Northwest Indiana
I need a real fix for this sticking pedal, not a cob job fix, but a permenant fix. When I purchased the unit they drilled a hole in the top of the "bushing" next to the hst pedal. They said put penatrating oil in in occasionally. Any time it rains, it locks up. I can put a half a can of penatrating oil on every pivot point, and in their drilled hole, and work the pedal 200 hundred times, and it will work it's way out over time. I can't stand it! I need it to work, this is insane, I need your help!
Thanks fellas.
AI
   / HST Pedal on ck20 sticking! AHHHHHHHHHH! #2
I don't know about a real fix but can you put a grease fitting in the holes your dealer drilled for you and put some waterproof/marine grease in them?
   / HST Pedal on ck20 sticking! AHHHHHHHHHH! #3
Never use penatrating oil as a lube! Pick up a can of penatrating spray Grease found at any auto supply store. If the bushings are plastic ,any thing like WD-40 , PB-blaster just makes it worse!
   / HST Pedal on ck20 sticking! AHHHHHHHHHH! #4
The sticky pedal is a pretty common problem. Even on my CK30 I need to keep a little lube on it. I will agree that the light wd-40 type stuff isn't permanent though it works great for the day! I have noticed a much stickier pedal after a good hosing gets water in the joint and washes the lube out.
I get on and off of the running tractor a lot and the creeping machine can be a problem.
   / HST Pedal on ck20 sticking! AHHHHHHHHHH! #5
there is a update that can be done to CK20.... to change to the same setup as a CK25 & 30. You should also put grease or never seize on it when installed. Any of the ck20's I have done like this have been trouble free since.
Do you have any specific info on this upgrade? I am interested, and my dealer does not know of any such thing, or did not offer it as an option.
I got a needle grease fitting, and was able to get some grease in it, but also discovered that they do not make these fittings for pneumatic grease guns.....Could make for a mighty fine dart gun.
It is working at present, but we are now receiving a deluge.
Thanks again as always.
AI
2015 Chrysler Town & County Van (A50324)
2015 Chrysler Town...
(4) HD 16' Corral Panels (A50515)
(4) HD 16' Corral...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
Lot (4) 16' Light Duty Pipe Gates (A50515)
Lot (4) 16' Light...
Noble 8 Row Cultivator (A50514)
Noble 8 Row...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
