Hi,
There have been some interesting explanations of HST's, mind if I add mine?
Ok, there are 2 parts to an HST tractor transmission. One part is the range selector, it is usually, Low, Medium and High. Then there is the peddle (or peddles).
I think of it like a 10 speed bike. Really, a 15 speed --> one with 3 gears on the front where you peddle. The left gear selector, moves the chain on the front gears from the little one for going slowly up hills to the biggest one for going down fast. That is the same thing the range selector does for the HST - low for power, high for speed.
On the bike, the right side gear selector moves the chain on the back gears. Up is for the biggest gear, down is for the smallest gear. When peddling up a hill, you move the lever up for more power (easier to push the peddles) at a slower speed. After you reach the top of the hill, you move the lever down for higher speed (but you have to peddle harder). That is exactly what the HST foot control does. As you push farther down, the HST tries to make the tractor go faster, but the engine has to work harder.
In my experience, the HST peddle gets confused with a car's gas peddle. As the engine reaches it's max output, they instinctively push the peddle down thinking it will give more power to the engine. Going back to the bike example - imagine you are ridding up a steep hill and as you begin to reach your max output, you push the gear selector down for a higher speed gear. What happens? You stall out, fall over red faced and panting. What you should have done was to pull up on the gear selector to go to a high power, low speed gear.
jb
