HST Hydraulic leak
/ HST Hydraulic leak #1
RobertDetomasi
McKinney TX
L3710
I have 1999 Kubota L3710 HST. Flawless performance for first 2000 hours of normal duty. Last 800 hours was very heavy plowing. Noticed hydraulic fluid leak. Checking fluid found no fluid in oil level window. Added fluid. Resumed normal duties(no heavy plowing). No more leaking. WHY???
So what happened? Overheated oil boiled over? Pressure relief valve worked. It's a mystery..............
/ HST Hydraulic leak #2
:welcome:
To TBN Robert. You came to the right place to get any question answered.
I can't help since I don't have a HST, but someone will be along that will have the answer.
/ HST Hydraulic leak #3
If you noticed the leak could you tell in what area it was coming from?
First thought is something on the plow circuit since this appears to be when you noticed the leak
FUEL TANK ON SKIDS (A63745)
FUEL TANK ON SKIDS...
Caterpillar TL1055D (A62177)
Caterpillar...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
Coats 5060AX Rim Clamp (A63118)
Coats 5060AX Rim...
