Hst/hyd drain plugs on Max
   / Hst/hyd drain plugs on Max #1
doneill127
CT
Mahindra Max
Getting ready to do the 200 hour hst/hydraulic fluid change on my Max22 Going with Chevron THF1000. I looked at the parts list and it shows the there are M12 seal washers on the 3 drain plugs. Does anyone know if these are reusable or are they like a crush washer that needs to be replaced ?
   / Hst/hyd drain plugs on Max #2
Most wouldn’t replace them unless they saw damage- like they stuck to the case and bolt and ripped. In a pinch you can add thread sealant. If you did have an issue your local parts store or hardware store will have something for you.
Bottom line- you should be fine.
Thanks guess I’m showing my age. A lot of stuff I’ve owned over the years have had copper crush washers that have to be replaced each time.
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
