HST goes backward, but not forward
   / HST goes backward, but not forward #1
aroostooksteve
Mahidra 2816 & Kioti RX6620
hi - I have a Mahindra 2816 HST. Runs fine. I was bush hogging a field and was backing up around a fence post. I noticed something on the ground and tried to go forward, but nothing happened. The pedal goes to the floor. The solenoid seems to be working fine. It goes in reverse with no issues. I just can't go forward. Any suggestions on what to check, how to fix?
Thanks!
   / HST goes backward, but not forward #2
Have you inspected the pedal linkage to see if anything got disconnected, bent or broken?
Everything I see looks normal and OK
   / HST goes backward, but not forward #4
Thanks!
That tractor has separate pedals for forward and reverse, right? Sounds like something slipped loose on the forward pedal. Check the pedal linkage.
   / HST goes backward, but not forward #5
Try changing gear ranges, and also shift to 4WD. No experience to say it'll work, but worth a 10 second try.
Thanks I will try all of these. I have a single rocker pedal. I push down with my toes to go forward and my heal to reverse. I checked the solenoid and it is moving with the pedal.
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A50322)
2017 Toro Z-Master...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
