HST & FEL Questions
   / HST & FEL Questions #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
I understand the HST pedal is a travel speed and directional pedal and not an engine speed pedal. Could someone explain how that transmission works?
Also, why isn’t there a lift and curl up (at the same time) position on the 7 way + float FEL joystick?
Just wondering,
TXDon
   / HST & FEL Questions #2
</font><font color="blue" class="small">( Could someone explain how that transmission works? )</font>
I wondered about the same thing a while back. When you have plenty of time, you might want to review the HST - How Does It Work? thread. I learned a lot from it. /forums/images/graemlins/wink.gif
   / HST & FEL Questions #3
Found this at tractorsmart.com under technical info. A lot of other good stuff too.
Hydrostatic Drive. There is nothing new-fangled about this transmission. It has been around for a long time. Nevertheless, it is among the least understood of all transmission types. It is common for it to be compared with the automatic transmission in an automobile. They are different animals altogether. The only similarity is that they both use oil to transmit power. Tech types describe a hydrostatic transmission as being a variable-displacement hydraulic pump, driving a fixed-displacement hydraulic motor. Now, to the un-initiated, that's a bunch of gobblety-gook. So let's s t r e t c h that explanation out a little bit. Any hydraulic pump's sole purpose in life is to deliver some amount (volume) of fluid to some other device, which in turn moves whatever is attached to that device, causing work to be performed. This can be either through linear motion (as in a hydraulic cylinder), or rotary motion (as in a hydraulic motor). If we want to control how quickly our device moves (or rotates), one way we can do that is to vary the amount of oil that the pump sends to it. If our pump is delivering four gallons a minute, things will happen four times faster than if we only pump one gallon a minute. (Are you with me, so far?) Since we can control our pump's output, we can control the motor's speed. Now, unless we just want to go around in a circle all day long, we've got to figure out how to change directions. No problem. (You knew that, didn't you?) Most hydraulic motors don't care whether they are turned clock-wise or counter-clockwise. (They probably don't even know the difference!) Since a hydrostatic transmission operates in what is called a closed loop system, consisting of the pump and motor units, we simply reverse the direction of flow from the pump, causing the motor to operate in the opposite direction. Oh, by the way, closed loop means that a fixed amount of system oil is trapped, or contained, within the pump/motor circuit. Assume that a certain hydro transmission is of a size that it contains 500 ml of oil within the closed loop. That volume remains constant, never changing regardless of tractor speed or direction. So, for any change that we make in the output volume and/or direction of flow of oil from the pump section, a reaction must occur in the motor section, inducing a corresponding change in motor speed and/or direction. In reality, there is a certain amount of oil that is constantly escaping from and being replenished back into the closed loop section of the transmission. This is because a small amount of oil is allowed to flow all around the various components for lubrication and cooling purposes. The greatest advantage of a hydrostatic transmission is the ability to infinitely vary the ground speed and quickly change directions. It's like having a million speed transmission. If you need a travel speed of 1.200589 MPH, it is available. Another advantage is reliability. This transmission is, by way of design, pretty much self-protecting from operator abuse. Also, on foot pedal controlled transmissions, there is a built in safety factor in that you need only lift your foot from the pedal, to bring the tractor to a controlled stop. The only disadvantage of note is a slight loss of power at the PTO shaft. You must also remember to apply the parking brake should you park the tractor on a slope. Hydrostatic is, by far, the best choice for turf mowing applications or for any tasks that require constant speed and direction changes within a small area.
If Harv's post has this info in it... My apologies.
   / HST & FEL Questions #4
The basics are here but there are several types or variations that different manufacturers are using currently.
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2012 Wells Cargo Enclosed Trailer (A53117)
2012 Wells Cargo...
Honda Pressure Washer (A53117)
Honda Pressure...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
