hpx has a friend to sit next tp now
   / hpx has a friend to sit next tp now #1
TOMMYHPX4X4
Veteran Member
schriever, louisiana terrebonne parrish
gator hpx 4x4
here is the new rhino 700fi. i got it two days ago . i will say that the reaend staying locked all the time really agrivates me. i can see that this thing will eat up the tires.now as for as spinning the tires she will do that i got out in the cane field and cut loose and she got sideways on the takeoff. nice sandy top soil !!! that true 4 wheel drive is a pain to steer and the rearend that stays locked makes it a bit diferent to steer but other than that shes nice .got some speed with her.
   / hpx has a friend to sit next tp now #2
The rhino looks very nice! I think it is time I traded up to the 08 from my 05.
me and a buddy was comparing the rhinos and it looks like the 700 has a diferent rearend setup . i think they went ahead and put in some brackets to help suport the rear diferential at the factory. plus the huge 4 disc bracks brings it to a stop fast not to mention the engine braking helps stop it too.
   / hpx has a friend to sit next tp now #4
Man, that is a slick rig.
Congrats,
D.
   / hpx has a friend to sit next tp now #5
nice ride. i liked 14 inch wheels with tera cross tires on the rhinos i had. i wouldn't go to aggressive on the tires if you care about your yard.
   / hpx has a friend to sit next tp now #6
Congrats Tommy! The first mod you'll want to make (unless they have already done so from the factory) is to get a bypass switch to be able to turn the speed limiter in reverse. From the factory I think mine would only go about 7 mph or something like that. Not nearly enough if you're bogging in some mud and need reverse to blast out. I also like the BlackRhino CDI box that increased the performance and raised the speed/rev limiter to allow mine to run just over 52 mph (according to my GPS).
With 27" Bighorns on mine it didn't tear up the yard too bad (I borrowed some 589's and they were brutal - probably pulled harder, but brutal on the lawn) and I only needed my winch when I got high centered. I could climb steeper hills than guys on ATV's would attempt. About the only thing I did that really sucked was jumped it about 4' in the air once. It landed really hard.
I went nuts on the mods with mine. All were great except the exhaust mods. I ended up going back to the factory exhaust. The aluminum billet exhaust tip really sucked. It made my Rhino have terrible low end power and made it run really crappy except at full throttle. I put in a Comet clutch with adjustable pucks to set how aggressive you wanted it to launch. Since I have a lot of hills that give you zero run up to them, I had the clutch set to be really aggressive. Although it would never pull the front tires, it would spin them for about 5' or so on asphalt when I stomped it. I know some guys who would have someone stand in the bed and yank back on the roll cage to get it to lift the front end, but otherwise it is actually front heavy (think about when I said I jumped mine), which is good if you climb steep hills.
I still have several of the stock parts from mine like the CDI, brand new wheels and tires with zero time on them, the stock carb, stock clutch etc. Isn't yours fuel injected? If so, that would make it about perfect. Get that reverse limiter removed, some aggressive tires, the CDI box and you'll go places you won't believe!
Oh yeah, you'll want to put you some front and rear stick stoppers for your CV joints on yours. I know you don't get snow and ice, but I shattered both of my front ones the first time I took it into deep snow. Hey, that reminds me, if you put a full smooth skid plate on the bottom and some really aggressive tires, I wonder if it will ride up on some of the mud in the swampy areas since you'll have the power to sling all the mud out of the tire tread. If you remember, mine would ride up on the heavy snow we had. It wouldn't do that with powder type of snow, but with the heavy wet stuff it was almost like a snow cat.
i wanna put some 26"589" and the bootsavers i wanna make some out of aluminum . but first i need to fab up a radiator grill thats a priority that thing is wide open. a lift kit of about 2"woudln't be nuthin to fab up now that i have a model to work off of.them hpx/xuv fenders are fixin to be started on and they should be nice if they come out as planned they will be alot nicer and stronger than the stock ones.
   / hpx has a friend to sit next tp now #8
Congrats Tommy,
On your new machine. Thing looks great !!! Keep us up with all the " goodies " your going to fabricate for the unit !!!
Best get a thinking on a bigger truck and goose-neck trailer. And your plans on the RTV in a few months or so, your going to need more hauling room.
Very proud for you buddy, you deserve everything you get !!!!
If you plan on getting a winch for the Rhino later, don't forget about the
new low-profile 9000 pounder ( think it's called a Tabor ) from warn.... It's Monster with a 100 ft of cable, and a 12 foot hand held remote .... And knowing your professional fabricating talents, you can build a mounting system for the unit ~~~~~ Don't stop now buddy, you are on a roll !!!!!
i think i'm gonna take the 2500 warn off my hpx and put it on my rhino for now. i am not really gonn use the hpx for any offroad stuff anymore it's my main worker and i need her to haul stuff but the rhino is gonna be the main afternoon pleasure rider. i'll keep you posted on the parts but i think the bota guys keep us bussy enough and then the deere then comes the rhino's but the botas got priority over them all.
   / hpx has a friend to sit next tp now #10
Well done Tommy, nice machine and well built.
I agree about the locked up rear end, very annoying.
I run a Honda Rincon, and like all Honda's and most ATV's the back axle is solid, no differential.
Now at lambing time on the farm the quad is in heavy use and reversing a trailer into the doorways of a shed to load sheep with a locked up rear axle is no fun.
Also when pulling heavy loads in the field, the quad just wants to go straight on, won't turn all because of that rear axle.
I'm looking into the possibility of getting a Polaris X2 700 efi with turf mode.
I really wanted the Arctic cat diesel quad, the 700D, sold here in Ireland by Massey Ferguson, but it also has a locked up rear axle.
I know performance is an issue but it has loads of torque.
For some jobs the quad is better than the Gator.
In any event, good luck with your new machine.
20X 8 SHIPPING CONTAINER (A52472)
20X 8 SHIPPING...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
