HPX Front CV Joint Boots
   / HPX Front CV Joint Boots #1
JESSE1
Veteran Member
Kilgore, Texas
JD 6400
With nearly 550 hrs, the front cv joint boots split on my HPX. My JD dealer ordered the boots and I dropped it off for them to be installed. I had been having problems with the clutch not completely disengaging at idle to I asked them to check it out. They found the rollers inside the clutch had flattened and it needed to be rebuilt. Ended up installing a complete new clutch since a rebuild would have been as expensive when labor was added in. It drives like new now. I had been noticing a rattling noise at times when driving slow and thought it might be the belt slipping. Turns out that it was the clutch rattling. Repairs were not cheap but the HPX is good as new now.
   / HPX Front CV Joint Boots #2
you doing good on the boots i'm on my 3rd set in the front no matter how good of a set of bootsavers you got when you go in the mud and trees them boots don't last long. i got over 700+ hours on the engine and clutch though and never touched them other than to clean them .
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
