Having issues with rear 3 pt not lifting with load on it at idle, works fine when engine rpm is above 1800 rpms. 2003 TC45D w/FEL The FEL works fine so I decided to tear into the HPL valve thinking that the o-rings behind it may be leaking. that was not the issue. but got a couple questions, should the bypass spool fall out of the control valve spool? or is it staked? also accidently bumped the parts tray and got the unload valve spring and the check valve spring mixed. Does anyone now which one uses the heavier spring. Still not sure what the issue is? checked pressure at rear remote 2450 psi. Anyone else every have this issue?
