HP vs Weight
   / HP vs Weight #1
Mpabe
Moreland, Ga
YM 2000
I am considering buying a refurbished YM and have narrowed it down to two models, the 2820D and 3110D, with FEL. The two tractors are very close in all aspects except weight. The 2820d is 3825 lbs and 31hp; the 3110d is 2733 lbs and 33hp. Only 2hp difference but almost 1,000 lbs different! For an all purpose tractor should I go heavy or light?
   / HP vs Weight #2
I would go heavier, although I suspect you are comparing the weight of a YM3110, instead of the YM3110D, (2910lb). You won't notice 2hp but will certainly notice the weight in traction.
   / HP vs Weight #3
Soft ground and grass, Turf tires ? Lighter might be good
But if you want to pull anything, Weight is king!
The Fordson is rated about 25 HP and pulls quite a load. The Hurlimann has 10 hp on the old gal and can hardly pull it's own weight even with 4WD. IT will go ANYWHERE, just not pull much getting there. On the other hand, The Fordson will get stuck on a slippery slope in winter without chains. The weight does not help there. (but with the chains on, LOOK OUT! ;-)
   / HP vs Weight
Both tractors are 4WD. Mostly I'll be doing FEL work and bush-hogging.
   / HP vs Weight #5
Make sure you know who you are buying this ''refurbished'' tractor from.. I would hate to see you get burned. That said,,,,I have a 3110D with liquid filled rear tires.. The relief on the loader will give B-4 it picks the rear of the tractor up..I usually have a box blade on the rear as well... I have a 160 koyker loader
   / HP vs Weight #6
Kenmac, do those weights appear to be realistic to you? I have a hard time believing the 2820D can be that much heavier then the 3110D, but that's according to tractordata.com. Does 3110 have aluminum drive train, where 2820 has cast iron?
   / HP vs Weight #7
I just looked up the YM2820D in the Yanmar Operation Manual I have (from Hoye) for the 20 series tractors. It lists the 2820 at 2936 lbs and the 2820D at 3165 lbs.
   / HP vs Weight #8
The different transmissions can weigh a good bit different.
Weight is king as it relates to traction. As long as the gearing is right it will pull.
Like the previous poster mentioned in the fordson...the old ford 8N will pull a double bottom plow all day long that will just make a similar HP yanmar sit and spin. The 8n i think has like 27HP but weighs like 2x what the equivalent ym would weigh.
   / HP vs Weight #9
What is just as important as weight is the availability of parts for a given model as well. Lots of 3110D's out there, 2820D ??? Before plunking down my money, I'd give Hoye tractor and Fredricks a call, ask about parts availability for both, which has more, is the 2820D orphaned ?? I'm guessing you are in it for long term, and it might not be needed now, but sooner or later it's going to be the difference between keeping it in service or parked for lack of parts with a big loss of value to the now parts tractor.
Chris
   / HP vs Weight #10
That sound a lot more reasonable to me. I have always questioned Tractordata specs on the YM2820.
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
Entyre Chip Spreader (A51573)
Entyre Chip...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
UNUSED CHERY INDUSTRIAL 10' - 18 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
