HP Question
   / HP Question #1
mjarrels
Elite Member
Virginia
1949 farmall, 1961 Fordson Dexta, 1986 Duetz Allis, 2001 Kubota.
I found some stats for my ford tractor that rated engine HP at 35, PTO at 32 HP and drawbar at 20.5 HP. I understand engine and PTO are about right but why such a drop for drawbar?
mark
   / HP Question #2
Could it be a they listed the drawbar hp wrong. Were you looking on tractor data. com. What model Ford is it. I looked up the hp ratings on my ford and it showed 4 hp less on the drawbar than the pto. 15 hp difference is a lot.
   / HP Question
1961 Fordson Dexta... easy 2 bottom plow tractor.
mark
   / HP Question #4
That's probably a typo. When I was shopping, I found from the brochures that one CUT had an inside wheel turning radius of 98 feet -- with the brake locked. :)
   / HP Question #5
I'd expect it to be about 23 hp at the drawbar. Really depends on what rpm they took the measurement.. and if that is a nebraska number.
A ford 660 with similar eng power has about 22.x hp at the drawbar.. etc.
Soundguy
   / HP Question #6
They musta had bald tires on that Ford. ;-D
   / HP Question #7
Some of the nebraska tests seemed odd to me.. they tested the 9n at a low rpm... showd way low hp on one of the tests..
Soundguy
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2014 FREIGHTLINER CASCADIA MID ROOF SLEEPER (A54607)
2014 FREIGHTLINER...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
Lawnmower Jack (A53117)
Lawnmower Jack...
