hp for 3 bottom plow?
   / hp for 3 bottom plow? #1
ohiooutdoorsman
Jefferson Ohio
looking to get my hands on a plow for this spring, 2 or 3 bottom... shouldn`t have any problem pulling a 3 bottom with a MF '65' 50 hp should I??
   / hp for 3 bottom plow? #3
Kind of depends on what you are going to be plowing and the type of soil.
Breaking sod in hard pan condiotions 2-14's would probably be load depending on your traction.
Easier pulling conditions 3-14's should not be a problem.
Pull type or semi mounted? with semi mounted you could probably pull 3-14's under most conditions.
Roy
   / hp for 3 bottom plow? #4
Used a MF 165 to plough many acres over the years:thumbsup: no problem at all,the tractor does have loaded tires so you may need to check to see if your's does.Power wise not a problem traction will be the biggest factor. Larry
   / hp for 3 bottom plow? #5
I like to work on 20hp per furrow but saying that we ploughed hundreds of acres for many years with 3x12in on fordson majors back in the day , Grip was more of a problem than power.!
   / hp for 3 bottom plow? #6
Horse power isn't necessarily what you "need" for ploughing. It's the "weight" of the tractor is what you're looking for (traction)...
I should not have a problem than. the tires are loaded and with the front end loader it goes about 6500 lbs, thanks for the insight guys.
   / hp for 3 bottom plow? #8
Stay away for a JD plow. They pull much harder than a Ford 101. or any other brand for that matter. Don't know ask me how I know. Ken Sweet
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2012 International 4300 Reefer Truck (A52748)
2012 International...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
