HP 101: What is necessary, what is overkill?
   / HP 101: What is necessary, what is overkill? #1
hrb111
Many of you have offered great advice and comments, and I'd like to pose another question: In our search for a nice $2K-$2.5K garden tractor to mow our 3.5 acres, one thing we are still unsure of is: How much horsepower do we need without going into overkill? One dealer told us that for our needs, 18hp is plenty. He explained that 10 years ago the same yard would have been mowed with 10hp and that every model year seems to add a horsepower and that much of it is marketing hype, etc. Then we had another dealer tell us that she mows her acreage with hills and trees with 22hp and that she probably needs more. Our acreage is rolling land, with lots and lots of trees. As I said in an earlier post, my husband is currently using a Simplicity 13hp (I think, I can't remember now) so it won't be hard to improve that. Also, he plans to do some light utility work, as well. Maybe push snow, pull a garden wagon here and there, etc. It seems that the tractors in our price range are going to be 22-25hp. Is this more than enough hp, or do we need to shoot for the highest that our budget will allow? Thanks in advance!
   / HP 101: What is necessary, what is overkill? #2
until a few years ago i used and 18 hp GT to mow alot of gass, my lawn, my parents lawn and a few fields, HP was never the problem. now i have a CUT AND still use the same 18 hp GT to cut lawn. if all you are going to do is cut grass, pull a cart for yard work and the ocassional little bit of snow then u should be able to do well with a gt in the $2500.00 price range. in MHO they put way to much emphais oh HP.
   / HP 101: What is necessary, what is overkill? #3
</font><font color="blue" class="small">( One dealer told us that for our needs, 18hp is plenty. He explained that 10 years ago the same yard would have been mowed with 10hp and that every model year seems to add a horsepower and that much of it is marketing hype, etc. )</font>
SORRY! forgot to add , this dealer was probaly the most truthful. seems they add HP to cater to the TIM THE TOOL TIME type of folks.
   / HP 101: What is necessary, what is overkill? #4
I used to mow my acreage with an 8hp kohler (wheel horse, belt driven 3spd transmission). It worked great, and was plenty hp for the 32" mower deck (two blades). Took me a while to mow the 5 acres however.
Then I moved to a 12hp Deere model 212. It had a 47" deck and I cut the mowing time considerably.
Then I went to a Deere 425, 54" deck, with 22 hp, and AWS (all wheel steer) with hydrastatic transmission and now mow 8 acres in ¼ the time I could mow the 5 acres with the 8hp Wheel Horse. Power steering, HST, bigger tires and can cover ground comfortably and faster. Go figure. The more hp just translates to mowing more acres in less time, and having fun doing it (at least that is that way for me). /forums/images/graemlins/grin.gif
Buy what you want and think you can afford, and then trade up (or down) after you get experience on the lawn you have, at the rate you want, and at the comfort level you want. You are the one to satisfy the most. /forums/images/graemlins/wink.gif
   / HP 101: What is necessary, what is overkill? #5
I think HP in lawn tractors can be figured based on how long you let the grass grow between mowings, how fast you want to mow, and if you have a very thick lawn or a somewhat thin yard.
If you have a thick lawn that you mow down to two inches when it gets to 10 inches and you want to mow it at the same speed that the neighbor mows his yard every three days, you're going to need more HP.
So it depends on what you're cutting and how fast.
Cliff
   / HP 101: What is necessary, what is overkill? #6
I'm with Frank on this one. My BX2200 is 22HP. The entry level JD 4010 I was looking at is only 18hp. Other than marketing I don't understand Sears, Lowes and HD selling 25hp lawn tractors.
I cut my yard with a Toro Wheelhorse 314-H with all of 14hp and I have never bogged it down.
I think the 22-25hp will be more than enough. But don't just go by HP. Lots of other factors to consider - deck size, gear vs HST, frame construction, weight, Dealer, Ease of use.
Phil
   / HP 101: What is necessary, what is overkill? #7
We cut lots of grass with lots of hills, gardens and trees. We have a JD LX188 (17 hp, liquid cooled, hydrostatic transmission, 48" deck). It is more than adequate for my needs and I would not have a riding mower without the hydrostatic. Been there and it was a pain. Things go much faster with the hydro. I have no problem on the hills. Lots of power and it never bogs down.
Hope that helps.
   / HP 101: What is necessary, what is overkill? #8
I use a 14HP rider to pull a 10 cubic foot trailer full of whatever I can get in it, cut 3 acres and sometimes 5 with 42" cut with no problem whatsoever.
The dealer was right, the HP is hype, and unnecessary for your uses. Mine is a two blade cut for the 42" for which 14HP is plenty. If you get a 3 blade, I'd go for the 18HP. No more. John
   / HP 101: What is necessary, what is overkill? #9
This is overkill. /forums/images/graemlins/grin.gif
   / HP 101: What is necessary, what is overkill? #10
Used to use a 12 hp with a 48" deck. Would mow about 1.5 acres of lawn and field. Then got a 11 hp Craftman with a 42" deck I think and it could got faster but it rode rougher.
Neighbour has a newish 20 something hp and it can't go any faster than us (too bumpy) but it has a wider cut.
We just stopped mowing the field and swamp and bushhog it in the fall now cutting it down to a half acre. If we could get some more trees and such planted we could get rid of half that too.
Sharpening the blades frequently lets you go way faster with still good cut. Big hp lets you spin dull blades.
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51246)
2018 GENIE GTH636...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2024 Bison Tek Skid Loader BT360 (A52384)
2024 Bison Tek...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
