Hows does a float circuit work
   / Hows does a float circuit work #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I have looked on the net and can't find what I am looking for.
When I put my bucket into float mode, what happens? Does the pressure that is going into the control valve get dumped back to the tank and the up down circuit just get connected together or is something else happening?
   / Hows does a float circuit work #2
When the spool on hyd control valve is pushed forward and locked in detent both "up & down lands on the spool are connected" to allow oil flow to travel in/out of both hyd hose ports of the boom cylinders so pistons are free to move back & forth in cylinder tubes.
   / Hows does a float circuit work #3
I guess you mean put the boom into float, not the bucket, but Jim explained it well.
   / Hows does a float circuit work #4
The float position allow the work ports/cyl fluid to flow to tank.
Fluid is still flowing through the valve for other spools.
There is no pressure until a cyl develops it.
Your lift arms will follow the conture of the ground. The movement of the bucket up/down will force fluid in and out of the lift cyl.
   / Hows does a float circuit work #5
J_J
I'M NOT ARGUING BUT ASKING. Are you positive the oil returns to tank when valve is placed in float or merely is displaced to the opposite side of each piston in each cylinder? If oil flows to tank then wouldn't each cylinder that had been placed in float experience some "lag time" to replenish depleted oil from float position??
Thanks,Jim
   / Hows does a float circuit work #6
He said allows which is correct.
   / Hows does a float circuit work #7
What I am thinking is that the cyls are acting like a pump and either push or pull fluid as needed.
If it is going to float, the fluid has to come from the tank.
If the flow was coming from the pump, you would have flow going to both sides of the cyl.
   / Hows does a float circuit work #8
J_J
Thanks,Jim
Both A and B lines are open to tank or the return circuit. So the fluid will either come from tank line in a power beyond valve or the pump excess / tank line in a non power beyond set up. You also use some oil from the cylinder to fill the other end of the cylinder from displacement like you said but that is very small. Remember because of the rod size being smaller than the bore upon extending you would have to have make up oil to fill the bottom and that comes from the return/tank cavity. CJ
   / Hows does a float circuit work #9
But if both lands on the spool valve were opened and ""pump pressure remained shut off"" couldn't oil flow from one side of cylinder piston to the other side of piston allowing rod to move in/out(vice-verse) without much oil going back to tank?? I understand that rod side of cyl holds less oil than the other side of the piston in the cylinder. I'm not stating no oil travels to tank but I think some of the oil doesn't while valve is in float. CJONE I was typing I guess while you posted. The difference in oil capacity compared from one side of piston to the other would be determined by cyl rod diameter.
   / Hows does a float circuit work #10
You can float a cylinder by opening the work ports and the tank port with the pump port blocked, or you can open all four ports. With the pump port blocked, power is available to downstream valves. With four ports open, the flow returns to tank and downstream valves are disabled.
Which one is used depends on what the control engineer wants to accomplish.
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
New Holland TS6.130 4WD 130HP Agricultural Tractor with Alamo Slope Mower (A55787)
New Holland...
Set 4- 12-16.5 tires/wheel for bobcat (A55787)
Set 4- 12-16.5...
2015 Acura MDX SUV (A55758)
2015 Acura MDX SUV...
2001 Club Car DS 6 Passenger 48V Electric Golf Cart (A55758)
2001 Club Car DS 6...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
