Howling hydro
   / Howling hydro #1
IMCA38
SE Nebraska
MF 1225 w/loader, Case 1840 SS, Ransomes 723D mower
Hi all
I just got done installing a cab on my Ransomes front deck mower.
Now, I really notice a howling noise from the hydro, espceially when its pulling, like uphill, or just taking off.
The hydro is an Eaton M-11 and it runs off the side of the main shaft via a belt drive.
First off a couple of observations:
1- with the addition of the cab, I'm sure it sounds worse with all of that going on underneath me and the cab holding the sound in.
2- the cab adds a lot of weight, probably 400-500#, so I'm sure it is working harder now to pull everything.
I mowed for about an hour and then checked it out. The hydro itself was not hot to the touch, so I don't believe there are any serious issues there.
My thought is this.
There is an idler pulley on the belt and it only has a spring to keep tension.
When it is running at idle, the idler seems to bounce the spring a lot, and I suspect it bounces more at higher RPM and under load, both hydro and main shaft running the mower deck.
I wonder if it would be a good idea to put something solid, maybe threaded rod w/ heim ends, to hold the idler at a constant tension.
I can't see that being harmful, the hydro on my tractor is hooked right to the back of the engine.
Are there other things I should check for the cause of the howling? Would it be harmful to tension the belt solid?
Thanks!
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
