Howdy...did I buy a whoopdee?
   / Howdy...did I buy a whoopdee? #1
markthoma
john deere f525
Hi everybody,
Moving out of the downtown area to a 1-acre house/lot a few miles out so I thought it might be a good idea to get a lawn tractor to mow all that grass! So the neighbor says his son-in-law (farmer) has a John Deere mower he'd be willing to sell for a couple hundred bucks. I took one look at it and said "Heck Yes!" The seller says it only has one problem....it'll run for a few minutes and then just die!
So here's the deal. It's a JD F525 (have no idea what year) and when I got it home I threw a battery charger on it, filled it with gas, and she fired right up. Ran for about 3 minutes and then just died. I pulled the float bowl on the carb and there was gas in it. I pulled the fuel filter and there was gas coming out of it. I pulled the spark plug and nothing. No spark whatsoever!
Bought a new plug, put it in this morning (the mower sat overnight) and it fired right up. Ran for 5 minutes and died. Same as before, no spark at the plug. So I'm thinking I must have a short at the magneto or in the plug wire. Does that sound right? Does this thing have a magneto? Does it have a set of points? Does the plug wire screw into the magneto is it a one piece unit. By the way the engine is some big honkin' Kawasaki 17 hp unit.
Any ideas?
   / Howdy...did I buy a whoopdee? #2
Welcome to TBN. I'd post your question in the garden tractor forum.
Good luck!
   / Howdy...did I buy a whoopdee? #3
Sounds like you got a real bargain.
The problem could be heat related. When it gets good and warmed up, something shorts out (or opens up) and it shuts off. You didn't say whether it starts back up or has to cool off first.
2006 UNKNOWN 16 T/A TRASH TRAILER (A53843)
2006 UNKNOWN 16...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
1996 Ingersoll-Rand VR642C (A47477)
1996...
72'' power rake (A53421)
72'' power rake...
