Howard rotavator
   / Howard rotavator #1
Hatcher
Cavan Ireland
MF35
Any idea how much gearbox oil is used in a 60" selectatilth rotavator?
   / Howard rotavator #2
Welcome to TBN. Its going to be a lot easier to find the correct answer if you could give the model number.
   / Howard rotavator #3
My rotavator has a dipstick on the top and it takes at least two quarts. Don't have my manual handy but will check later
   / Howard rotavator #5
I have three Howards, two are selectatilth and the other day one was a little low, it took a quart to top it off, so I'm sure it holds over two quarts, probably three...
SR
   / Howard rotavator #6
The manual said Howard Rotavator Model HA-V.
It calls for SAE 140 6 pints in the gearbox (fill to dipstick) and 2 pints in the chain case (fill to level of plug).
   / Howard rotavator
Thanks Oosik. Model is E series 4. I got all info I required online. Many thanks for your input
Hatcher
1268 (A50490)
1268 (A50490)
2014 MACK CXU613 MID-ROOF SLEEPER (A50854)
2014 MACK CXU613...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A49461)
2014 Peterbilt 320...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
