How would you cut a 1" thick piece of cast iron?
   / How would you cut a 1" thick piece of cast iron? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
I'm not sure if it's possible or practical. I was telling my neighbor about a couple pieces of old pipe i found next to a woods road (trying to figure out a way to break them up into manageable pieces to get the $800+- scrap value) when he mentioned he could use some of it for grates in his maple syrup evaporator. That sounds like more fun... suggestions anyone?
   / How would you cut a 1" thick piece of cast iron? #2
portable bandsaw or saws all. If it is really cast iron. If it is poorly made CI it will eat blades.
Steel you can torch it.
   / How would you cut a 1" thick piece of cast iron? #3
would a snap cutter not work to cut a managable size piece?
Thanks.
He wants several 6" by 3ft pieces, seems like it would take a lot of sawsall blades.
it's worth a try though. i'll bet they'll make good grates.
   / How would you cut a 1" thick piece of cast iron? #5
Don't know what kind of tools you have available.
Plasma, carbon arc, demo saw.
I had to do a search to see what you meant. Guess I should have mentioned the pipe is 31" OD. If it's possible, he may find it cheaper to take it to a machine shop.
   / How would you cut a 1" thick piece of cast iron? #7
A chain cutter rental, would seem in order, otherwise a pair of safety glasses, and a sledge hammer...........
YouTube - Removing Cast Iron Pipe
~Scotty
OH! Just saw the 31" OD! Wow!
   / How would you cut a 1" thick piece of cast iron? #8
$800+ for scrap metal sounds like fun to me...wish I could stumble across something like that! I'd find some way to get it to the scrap yard, I guarantee that...
   / How would you cut a 1" thick piece of cast iron? #9
I'm missing something. How do you get a 6" X 3' piece. out of a 31" diameter pipe? ~S
   / How would you cut a 1" thick piece of cast iron? #10
its obvious.. the answer is
UNUSED WOLVERINE PT-16-01C UNIVERSAL ADAPTER (A51248)
UNUSED WOLVERINE...
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
2005 National RV Inc. Dolphin LX RV (A53117)
2005 National RV...
