How would you clean this up..
   / How would you clean this up.. #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I have a fence row in front of our house that is pretty much paradise trees, briars, and locust trees that I would like to clean up.
You can see some pics of it here..
http://s49.photobucket.com/albums/f292/Tracy_Brian_House/Misc Pics/
One problem is that there is a major telephone line running on top of the bank just inside the fence, so pulling or pushing over the trees may not be an option..
I thought about just grubbing the small stuff, cutting the trees down, and using the FEL to pull up the fence and fence posts.. But I think everything will just come back next year.
What if I sprayed it with some sort of weed/grass killer after I cut everything back.. Would that keep it from growing back in the future?
Suggestions are welcome
Brian
   / How would you clean this up.. #2
Have you contacted the phone company responsible for that line? In most places, they are responsible for keeping the trees trimed back fromt the wires. If you contact them and they don't seem interested, there are always regulatory agencies that oversee all utility companies. Calling the agency in charge will get results that you will find hard to believe!!!
If the trees are trimmed they don't have to do anything, (darn) then the fastes and easiest way I know of to take out smaller sized trees like that is with a dozer. Total control of where you push them and there's no worries of them going the wrong way. A decent sized dozer or track loader, or even a trackhoe should be able to lay them down in a few hours with the roots attached.
The fence will be ruined, unless you don't have a fence, but you'll be left with just dirt to grade and smooth out for a very nice, clean, open area.
Doing it by hand is too labor intesive to be practical or economical. For what you could hire it out in a day, would take you months or even years to do the same thing with a chainsaw and CUT.
Good luck,
Eddie
The phone lines are buried about 2' back from the fence line and about 12" or so down (IIRC).. The builders had a little trouble cutting in our driveway because the lines arent that deep..
The trees arent really that near the lines, but if you started to pull/push them I think you may end up snagging the lines..
either the realtor or the developer of the land across the road from us just had someone clean out the entire fence row for a future development. They have lots that havent sold in almost 3 yrs, so they are trying to get them moving by cleaning up the appearance.. And I was thinking of getting that guy to do it for me.. he had a large ag tractor and was just pushing over 15' cedars with ease (we also had a couple inches of rain recently that helped im sure)..
What would a fair price to clean this up.. We are talking about 200', just right in front of the house.. I want to plant some sort of windbreak/screen evergreens to slightly shield the house.
thanks
Brian
   / How would you clean this up.. #4
To add to what Eddie said about the phone company, here, in Texas, you can get the highway department to clear it out. A friend had nearly 1/2 mile along a Farm to Market road cleared of cedars/scrub brush and old fence line by the county. It didn't cost him a thing. Once cleared he put in new a fence line. The county did pile the debris on his property to dispose of.
It is worth checking into before you start laying out money to hire someone to do it and still run the risk of damaging telephone cable that you may end up being held responsible for damaging.
   / How would you clean this up.. #5
Hard to believe that the phone company would bury a main line only a foot deep. Think I would call them to mark the line and tell you the depth. Then as long as your not clearing directly on the area they marked if the line is damaged it is their problem.
MarkV
   / How would you clean this up.. #6
I am not sure where you are located, but here in New Hampshire all roads have a classification as to width. Most country roads are three-rod roads and looking at your road the brush might fall into the road right-of-way? If so you might want to contact the town and see if they will do something about the mess, worth a try.
In NH you can have a country lane with no width registered, country road East and West running with two rod road limitation and country road North and South with three rod road widths. State highways are four rod and larger.
As for the Telephone company around here they are really monitored for any underground line. Like public service the telephone company requires the lines to be a minimum of four feet down with 12 inches of sand beneath and the line must be incased in the proper tubing. Our problem around here is rocks and water table. I would think if the telephone company put that line in it is not properly installed.
Eddie has the right approach to this by using a dozer. I guess one could push down away from the telephone line and do minimum damage, then do a cleanup with either the dozer or a tractor. I think I would stay away from spraying the area as you will kill the growth, but not the roots and the brush will come back quickly maybe even faster with more open space to spread.
Just my thoughts.
Wayne
   / How would you clean this up.. #7
Brian,
I'm thinking a dozer would make quite a mess. Once it where pushed out you would need to bring dirt in and get that seeded to control erosion. That's after you cleaned up the debris. A track hoe with a thumb would make quick work of it but you still would need to fill it back in and get it seeded.
If it's only 200' with a single line of smalls trees I would pull what you can then cut the larger stuff flush to the ground. It looks to me like you could mow over it to control any regrowth. If you are worried about hitting a line with the taller stuff you can ask the utility company to come in. Around here that means they will top the tree but will not take the whole thing down. If you have a grapple the cleanup would not take long.
dsb
   / How would you clean this up.. #8
Good luck,
Eddie
Who regulates cable compaines?
They arent covered by The P U C O here.
   / How would you clean this up.. #9
   / How would you clean this up.. #10
Look for posts by Robbie Hedgewood. He has a mulching unit attatched to the front of a skidsteer type tractor that would eat right through that (less fence wire). Your profile is blank so I don't know where you are located (Robbie is in Georgia), but may be one of these units for rent in your area. I think his latest post was in the Safety section where he turned his unit over. Maybe he will chime in and give you some direction.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2239 (A51244)
2239 (A51244)
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
