How would you build a loader-mounted gin pole?
   / How would you build a loader-mounted gin pole? #1
jimgerken
Veteran Member
Minnesota
John Deere 3720
If I want to lift things to a height which is higher than my loader, I imagine using a gin pole. At first I was thinking of bolting and chaining it to the bucket but now I am thinking it may be easier to simply remove the bucket and fabricate a new plate with just the gin pole on it. Has anyone done this or thought through it enough to have some good ideas? If so would you care to share your experience? Thanks!
   / How would you build a loader-mounted gin pole? #2
Just don't forget that the additional leverage of putting the weight that far out in front of the tractor will severely reduce the amount of weight you can handle on that gin pole as compared to the rated weight for the front end loader.
   / How would you build a loader-mounted gin pole? #3
We made one out of two pieces of gas pipe and put it on my dad's old John Deer. 'Used it to move 50 foot trusses into place. A boat winch mounted on the tractor with a cable through a pulley at the top of the a frame made things much easier - remember, you want to keep that load as close in as you can so using a cable to lift is more stable then running your loader. On anything less then a full size tractor I would be extremely wary. Work out the weight and balance issues on paper first and make sure its worth it.
Andy in NH
   / How would you build a loader-mounted gin pole? #4
That's right. The longer the lever, the less weight it requires to bend the loader mechanism or, worse yet, tip the tractor.
<font color=green> MossRoad </font color=green>
2006 FORD F250 SERVICE TRUCK (A53426)
2006 FORD F250...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
Kubota RTV-X1100C 4x4 Utility Cart (A51691)
Kubota RTV-X1100C...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
