How to wire sewer ejector pump
   / How to wire sewer ejector pump #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
Have a remote cabin up north and I have an inspection coming up where I'll need the sewer ejector pump to function. For the record, this place is off grid and the inspector says no electrical permit is required. That said, I'll pay him a fee to come and perform an inspection just to make sure I did things right. The pump is a 2hp 220v grinder pump that is outside of the home. The pump is in a 300 gallon plastic tank. The tank lid is flush with grade. I've never wired up a pump like this so I'm a but confused as to how it's done. Per the instruction manual, there appears to be a junction box where the pump wires and float wires are connected to the service. From what I can find on line, this box would be a 12x12 plastic box and you bring a 2" conduit out of the box and then pull the pump and float wires through the conduit. The wires are then potted to seal the conduit. A electrical plug goes in the box and the pump gets plugged into the outlet so the plug serves as the disconnect. Ok, that all makes sense. What I can't figure out how to bring a conduit from the outlet inside of a box through the tank wall. Anybody ever wire one of these? Pictures would be appreciated!
   / How to wire sewer ejector pump #2
Is there no pass thru molded in the tank? Threaded female fitting molded in the tank where you can screw in a nipple. threaded pipe or what have you? In the cover?.............Mike
Honestly, I don't remember. I put the tank in 7 years ago and it's 2.5 hours away so I can't check it. The hardware store is an hour away from the cabin so I was hoping to just bring everything with me and then return what I don't need. Looking at the tank cut sheets, I now see a 1.5" SCH 80 pvc pipe grommet in the side opposite the pipe inlet. The fitting is set low and horizontal so I'd have to run a pipe into the bottom of the junction box which would be mounted in the riser. Ok, that makes a little more sense. I presume you just shove the conduit through the grommet. Is there a short length of exposed NM in the 12x12 box before it gets to the outlet enclosure?
   / How to wire sewer ejector pump #4
Not sure.
Can't see that happening. What would prevent effluent from leaking out or groundwater leaking in? You think it would have to be tight, not just shoved in. I know when they did my daughters septic next door the liquid tank had a pump. The electrical feed was from the side at the top and went thru a fitting that was liquid tight.
   / How to wire sewer ejector pump #5
One thing for sure is that you want all connections sealed off, potted or otherwise protected as the contents of the sewage is very corrosive and will play havoc with any exposed wire or connectors.
While they often provide plastic junction boxes I also have cut all plugs and soldered my connections using waterproof type shrink sleeves.
The waterproof sleeves contain a hot melt glue that does an excellent job.
   / How to wire sewer ejector pump #6
There should be a fitting on the box with a rubber grommet. You pass the pump cord through the fitting with the grommet on it . Tighten the fitting and the rubber compresses around the pump cord. All wiring should be done in the water proof box ( it will fill with water if the pump quits). So you use wire lugs filled with die-electric compound to seal the connections inside the box.
I've had the die-electric compound filled lugs underwater for days when a pump fails. Zero shorting/grounding out. Never reuse one, always use a new lug.
The electrical service disconnect should be a separate box on a pedestal or on the side of the house and properly labeled, never use a plug in a water filled box. Good way to get dead or get someone else dead.
   / How to wire sewer ejector pump #7
I have done a couple of these in the past. If you have the manuals at home; post pictures of the tank, pump, and control panel. The power through the tank top or side should be a 1/2" or 3/4" threaded connection point. Normally a 220 pump does not use a plug and receptacle disconnect means. Lot of info missing here to provide you with a bill of materials for you project.
Ron
   / How to wire sewer ejector pump #8
Ron
Agreed. Need more info. You mention 300 gallon plastic tank, but that could be meant for potable water, sewage, or for spraying chemicals. And between those types are the different manufacturers. That's kinda like asking for help fixing your lawn mower, without even knowing if it's a rider, push, self-propelled, what brand, etc.
Then there's the grinder pump. Make/model? How will you be powering the pump - solar? Battery bank with converter? Generator? Is your electrical system properly grounded?
What happens when the tank fills - do you take the tank and dump it? Have Roto Rooter come and suck it out? Build a drainfield? Btw, dumping the waste is illegal. Then again, you said it's buried, so no problems there.
What all is going into the tank - just sewage? Bath water? Sink water? Any sump pumps there? If so, where do they get pumped to?
Going by the information given, it makes sense that you "probably" either have a drainfleid set up, like a complete septic system, or that you plan to suck the contents out on occasion. Also, there must be some sort of vent on the tank - otherwise, pressure would build up inside as more and more sewage gets drained into it. So if your tank has no predetermined points for conduit or wiring, then it would make sense to have those access through the top, and have an insulated cover over the tank to also help prevent anyone driving over the thing.
   / How to wire sewer ejector pump #9
Your pump and float switch come with long rubber cords. Do not shorten them. Leave excess in tank and make sure these cords do not interfere with the floats action. Bob
Here is the pump: Dropbox - 998422.pdf Dropbox - A-23 GrinderAutomatic7-6(9-11-8) (1).pdf Looks like the cord ends come bare and the float switch is wired into only one of the hot legs. If I just put a junction box in the tank, then that would simply the installation greatly, but I'll now need a disconnect.
This is the tank: Dropbox - Print - www.akindustries.com_pdf_AK-CATALOG_rev3.pdf It's the round one on page 3. More information is on page 12.
Because power is intermittent, I don't have a control panel. I installed a float gauge in the tank and will have to monitor the water level and then manually turn the pump on. A float switch would shut the pump off. Monitoring the sewage level shouldn't be too difficult because we have to haul the water into the site.
What I think I'll do is put a non-fusible disconnect at the riser and then run a 1.5" pipe down into the tank neck. I'll pull some SOOW or SOW wire through the 1.5" conduit into the tank. Put a 6x6 junction box inside of the tank and make the pump and float connections in this box. The conduit will not make a hard connection to the junction box. I'll run the pump and float wires to the disconnect if I can, but I'm not sure they're long enough. That'll simplify things pretty nicely.
PT 1000 Gal Supply Tank (A44501)
PT 1000 Gal Supply...
2015 WESTERN STAR 4900 SB (A45046)
2015 WESTERN STAR...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A43004)
2016 FREIGHTLINER...
(60) HIGHWAY TRAFFIC CONES (A45046)
(60) HIGHWAY...
2018 TURNKEY INDUSTRIES  DATA VAN (A45333)
2018 TURNKEY...
2015 TREMCAR PNEUMATIC TRAILER (A45333)
2015 TREMCAR...
