How to understand oil test results?
   / How to understand oil test results? #1
davygp38
where NY,NJ, and PA all meet
Kubota L4400
I took the first step to buying a 5-6 ton excavator, by registering with Iron planet. I like the idea of their guarantee. I don't have a clue as to how to decipher the oil test results that they post on the inspection report. I have searched this site, and cannot find any links, or postings on this. I was using key words (oil test,) (oil analysis,) etc. Any help will be appreciated.
   / How to understand oil test results? #2
Try using their support.
   / How to understand oil test results? #4
I haven't bought off Iron planet in years but they use to include a discription from the lab. It may have been if there was something was out of normal range. For example if the copper content was high they would say something like possible worn bearings. I use to work for a guy who did oil analysis as part of the business. I never did any of it. He would include a basic sheet for things like engines, transmissions, etc with expected ranges, generic reasons if any range was out, and what to look for to narrow down where to look, say oiil pressure in the case of high copper.
I cant find anything on the iron planet site, to help me out. The link from Blackstone labs, is not to helpful, because it more or less shows what Blackstone labs does in their oil report. Blackstone breaks down, what the normal range is for your specific machine, and the universal averages. Iron planet does not. It is on you to find out what is the acceptable range for the machine in question. I did learn that Glycol is badddd:D
   / How to understand oil test results? #6
Oil analysis laboratories tend to provide training that is much more in-depth than what you as an end user wouild want. Analyzing the data on your own is not easy and can cause you to make a poor decision or pass by a machine that does not have any real issues. It is best to rely on their analysis comments. A major hurdle you face is that a single oil sample report does not really tell you enough solid information about the engine, hydraulic system or transmission. A series of samples over time provides more reliable data. Analysis data should not be taken at face value when you are looking for wear metal trends. On a single report, you get a "number" for iron (Fe). Without having benefit of previous sample history, you do not know if that number is escalating or falling. Just a hard limit is of little consequence. For some engines a silicon (Si) value of 50 PPM could be considered to be possible evidence of dusting (air filter problem) while another engine manufacturer considers an Si number of 7 PPM to be the tipping point. I know of such an engine make (not found in tractors but in mining trucks). Engine companies do not as a rule publish wear metal limits.
More obvious data that may be of help is a report of antifreeze content or fuel dilution. However, you seldom find any sample report that shows antifreeze content as the oil temperatures are high enough to boil off the coolant and water. Unless you know what to look for in the traceer elements can you see coolant in the lube oil as a problem. Specifically, look for presence of sodium and potassium as they are found in coolant chemistry. Some coolants use borate buffers. Analysis would show a coolant leak as higher boron. But boron is an additive element. Sample results may not show fuel dilution depending on the initial test method. Some labs use a Seta Flash test. A sample of the oil is heated in a shallow dish. As the lube heats up any fuel in it will vaporize. A flame is introduced above the sample. If it flashes, it is an indication of some threshold percentage of fuel, around 5%. What about a 3% dilution? Much more expensive analysis is needed to accurately detect that. I doubt that anybody selling a machine like that would invest in a sample that may prevent the sale. Basic analysis provides wear metals, glycol test, fuel dilution test, additive metals and elements. What you need is a test for used oil viscosity at 100C and TBN, oxidation and nitration. These are tests for the oil quality and how the engine lubricant has been treated. Bad sample reports can be easily doctored by testing a lubricant that has very low hours of run time. The results will be better for certain while not representing the truth. A series of samples is a better deal by far.
Let's take a different tack on this matter of purchasing a used excavator of any serious investiment in a machine. You will pay more for a used machine that you buy from a local equipment distributor. You have a better chance finding oil analysis history from the previous owner. It is in the interest of the seller to have this data. If they do not have it, keep looking. Buying from an established dealer is safer in that his reputation is at stake if he sells a machine that ready for major repairs but is not sold like it is. Somebody selling a machine over the internet has no real concern about that. Equipment sold at auctions may have some of that backing but you pay more. If you are looking for a bargain, there are no good deals that a simple report will protect you from getting stung. I have 15 years experience with two Catepillar dealers in the service industry. On more than one occasion we had customers who bought machines at auctions or from a non-local sale. They were stung big time. One of them bought a track loader that had complete junk in the transmission and steering clutches. The final drives were also trash. Still, the tractor would pull it self around. Ran well enough to unload it from the lowboy trailer. The ensuing lawsuit did little for the new owner but to make him wiser. There are no bargins worth pursuing.
As for more information about oil analysis check this site out for more resources:
Oil analysis - Wikipedia, the free encyclopedia
   / How to understand oil test results? #7
Metal showing up is quite common, amount of metal from continuous testing shows more about conditions.Coolant can still be in a sample, depending on the leak.We use testing for most of the costly equipment, test both the oil and coolant, by the labs.I also cut the top off the engine oil filters and fuel filters to have a look at them.
Oil analysis laboratories tend to provide training that is much more in-depth than what you as an end user would want. Analyzing the data on your own is not easy and can cause you to make a poor decision or pass by a machine that does not have any real issues. It is best to rely on their analysis comments. A major hurdle you face is that a single oil sample report does not really tell you enough solid information about the engine, hydraulic system or transmission. A series of samples over time provides more reliable data. Analysis data should not be taken at face value when you are looking for wear metal trends. On a single report, you get a "number" for iron (Fe). Without having benefit of previous sample history, you do not know if that number is escalating or falling. Just a hard limit is of little consequence. For some engines a silicon (Si) value of 50 PPM could be considered to be possible evidence of dusting (air filter problem) while another engine manufacturer considers an Si number of 7 PPM to be the tipping point. I know of such an engine make (not found in tractors but in mining trucks). Engine companies do not as a rule publish wear metal limits.
More obvious data that may be of help is a report of antifreeze content or fuel dilution. However, you seldom find any sample report that shows antifreeze content as the oil temperatures are high enough to boil off the coolant and water. Unless you know what to look for in the trace elements can you see coolant in the lube oil as a problem. Specifically, look for presence of sodium and potassium as they are found in coolant chemistry. Some coolants use borate buffers. Analysis would show a coolant leak as higher boron. But boron is an additive element. Sample results may not show fuel dilution depending on the initial test method. Some labs use a Seta Flash test. A sample of the oil is heated in a shallow dish. As the lube heats up any fuel in it will vaporize. A flame is introduced above the sample. If it flashes, it is an indication of some threshold percentage of fuel, around 5%. What about a 3% dilution? Much more expensive analysis is needed to accurately detect that. I doubt that anybody selling a machine like that would invest in a sample that may prevent the sale. Basic analysis provides wear metals, glycol test, fuel dilution test, additive metals and elements. What you need is a test for used oil viscosity at 100C and TBN, oxidation and nitration. These are tests for the oil quality and how the engine lubricant has been treated. Bad sample reports can be easily doctored by testing a lubricant that has very low hours of run time. The results will be better for certain while not representing the truth. A series of samples is a better deal by far.
Let's take a different tack on this matter of purchasing a used excavator of any serious investment in a machine. You will pay more for a used machine that you buy from a local equipment distributor. You have a better chance finding oil analysis history from the previous owner. It is in the interest of the seller to have this data. If they do not have it, keep looking. Buying from an established dealer is safer in that his reputation is at stake if he sells a machine that ready for major repairs but is not sold like it is. Somebody selling a machine over the Internet has no real concern about that. Equipment sold at auctions may have some of that backing but you pay more. If you are looking for a bargain, there are no good deals that a simple report will protect you from getting stung. I have 15 years experience with two Caterpillar dealers in the service industry. On more than one occasion we had customers who bought machines at auctions or from a non-local sale. They were stung big time. One of them bought a track loader that had complete junk in the transmission and steering clutches. The final drives were also trash. Still, the tractor would pull it self around. Ran well enough to unload it from the lowboy trailer. The ensuing lawsuit did little for the new owner but to make him wiser. There are no bargains worth pursuing.
Wow, thanks for all the info. I am going to take your advice to heart, and talk to my local kubota dealer first. They have low hour rental machines complete with service histories. I will keep checking out Iron planet auction results though. Thanks for the link on oil analysis,
   / How to understand oil test results? #9
Hey friends thanks for the sharing huge information.. it is very useful to everyone.. :thumbsup:
   / How to understand oil test results? #10
Well no one on here is a tribologist or anything. I have done and read oil reports for 20+ years and the best in the market is Dyson Analysis. It is more then the cookie-cutter test houses.
Funny I work on Military trucks and they do not cll for oil drains...All done by analysis; same with trannys.
2001 Ford F150 (A50121)
2001 Ford F150...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
