dknarnd said:
May want to trailer our ford Windstar about 1300 miles one way and I was wondering what the best or most economical way to do this is. I know best and economical are never the same but what are my options? Would a haul car dolly where the rear wheels stay on the ground in toe work for a trip like this or should I use a full trailer? The toe vehicle would be a 2004 GMC Crew 5.3L and 3.73 rear.
Best bet is a full car hauler. That is evident. Saves wear and tear on everything and to me, the rental investment would be worth it. For 1300 miles, it may be a return on the investment to buy a double axle trailer, use it, then sell it. At least you'll get some if not all of your money back. That may not be an option for you. Rental is 100% loss to U-Haul.
Next bet just as good: Tow dolly.
I have towed extra work cars and such as I travel around to various plants to work. I use a U-Haul dolly and it works just fine. Simple, easy to rent, easy to drop off when done. Very easy to load (tilt ramps) and light hook-ups are generic. Safety chains come with the trailer (by law) but I am also saying that safety chains come with the dolly for a safety hook-up to the vehicle onto the dolly.
One thing to heed.. Never load a vehicle onto a dolly backwards. Weight distribution (or lack of, from the engine being at the rear and no tongue weight) will wreck you. Plain and simple. I have seen it and it almost happened to me. One sway and it's all over. Load it up forward...
I used to carry a trailer everywhere but storage is often difficult at a temporary site. Thus the dolly, easy to drop and forget about. Thirteen hundred miles is not that much wear and tear actually. The dollys are stable and heavy-duty enough to suit my comfort zone at ~70 MPH (or more). Don't drive like I do please. I am a big fan of heavy diesel foot.
You'll load it on frontward, cinch the wheels with the ratchet straps, unlock the swivel on the hitch, leave the steering wheel unlocked. Your rear wheels will roll independently, as most vans are front-wheel drive.
If you're dealing with a drive-shaft onto the rear axle, then we need to discuss plan B.
When stopping always plan a parking and exit route to not have to back up. You now have two points of pivot, one at the ball hitch and another at the swivel on the dolly. It can be tricky to back in reverse direction. Always plan an out in forward.
I think the dolly would best serve your needs with the 5.3 and the 3.73:1 gear. The trailer will add considerable weight for the 5.3. The dolly will indeed serve a good purpose. I have done this a dozen times or more, both short hauls and long hauls.
