How to torque a hydraulic fitting
   / How to torque a hydraulic fitting #1
Furu
Platinum Member
May be a dumb question but the only dumb question is the one that is not asked.
My question is how to torque a hydraulic fitting but the question generally is when you can't get a socket torque wrench on a bolt/nut/fitting how do you torque it to a specific setting. Using crows feet and a normal torque wrench and math I think it could be done with some degree of error due to angles changing but is there a better/simpler method. Of course one can always tighten it till it feels right but that doesn't always turn out well.
   / How to torque a hydraulic fitting #2
   / How to torque a hydraulic fitting #4
Here is yet another resource for the math:
Torque Wrench Adapter Extended Calculation - Engineers Edge
May be a cut-a-way socket could work, like the ones used to remove oxygen sensors from the exhaust system. Doesn't seem practical though, the rigidness of the hydraulic line and diameter to nut size of the fitting would require a very long socket. Just thinking...
   / How to torque a hydraulic fitting #6
Some type of fittings may use a criteria that involves the number of turns after finger tight snug.:)
   / How to torque a hydraulic fitting #7
wow.. I must be doing it all wrong. :)
I just put em in till they feel good and go.. and that accounts for npt, orb and jic.... I better start getting high tech and get the TW out.. ;)
soundguy
   / How to torque a hydraulic fitting #8
I am with SoundGuy, I have never used a torque wrench on hydraulic couplings. Just tighten till it is snug. Hydraulic fittings dont take a lot of torque to be leak tight so a bit more than snug is about all you need. If it leaks, which I have never encountered, tighten it a bit more.
If you are built like a young Arnold S. then maybe you need to torque everything, but I have found that after a few years of practice and knowing how much it takes to twist off a bolt, experience is better than torqueing. Torque wrenches dont take into consideration the friction factor and sometimes you can reach specified torque and the bolt will still be loose whereas a really well lubricated bolt may be overly tight when torqued to the max.
   / How to torque a hydraulic fitting #9
I have often joked that the best way to properly torque a bolt without a torque wrench is to tighten it until the head snaps off then back off a quarter turn.
   / How to torque a hydraulic fitting #10
... or to tighten till just before it breaks off.. :)
soundguy
TMG-DCP2020 20ft X 20ft Outdoor Dog Kennel Playpen (A42745)
TMG-DCP2020 20ft X...
2015 KENWORTH T680 (A45046)
2015 KENWORTH T680...
New/Unused 14ft Bi- Parting Iron Gate (Deer Design) (A44391)
New/Unused 14ft...
PALLET OF WELDING SUPPLIES (A45333)
PALLET OF WELDING...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
2019 KENWORTH T3 SERIES (A45046)
2019 KENWORTH T3...
