How to time a 3 cylinder kioti
   / How to time a 3 cylinder kioti #1
Derekoo1095
Dk 35 kioti
I put in new injectors new fuel lines new fuel filter a newly rebuilt injecter pump I didn't time it I was told it won't need it so it starts and blows white smoke it will run good for awhile and then loose power then it will catch it self run good again blowing white smoke not sure what to do
   / How to time a 3 cylinder kioti #2
What was the status before you went through the fuel system? Why did you go through the fuel system? Is the current behavior similar to where you started? The white smoke is generally indicative of a cold engine and should soon disappear. Continued white smoke can indicate water getting into the combustion chamber - not a good thing as you have surmised. Do you have any water in your oil? Does oil appear in your coolant? As far as the timing goes, you'd probably have to have access to the shop manual for your tractor.
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Peterbilt 377 Semi-Truck (A55218)
Peterbilt 377...
