How to test LT106 coils ?
   / How to test LT106 coils ? #1
danyboy
Is there anyway to test the coils on an LT106 John Deere tractor ? My son said he suspects the coils to be shot (he tried with other coils and the engine would run but a little weak).
The problem is if I buy him some new coils, you can't return them if the problem is elsewhere.
Danyboy
   / How to test LT106 coils ? #2
Coils generate a spark that is measured in 10K volt increments. 30-40-50 thousand volts (or more depending upon the particular coil). You'd need a pretty good voltmeter..
Also need the OEM specifications for the coil. You could test the impedence and/or the voltage output - but you will need to know the acceptable range of values for that model of coil.
Your dealer (shop foreman or part's manager) might be able to look up the reference values for you as well as a recommendation for testing.
AKfish
Thanks a lot for the info. I finally went to the John Deere dealership. They agreed to test my coils on a demo LT166 tractor. I guess they weren't aware of your coil testing technic.
Danyboy
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
11 SERVICE BODY BED (A53843)
11 SERVICE BODY...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2021 Top Hat Bumper Pull Equipment Trailer (A53117)
2021 Top Hat...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2017 Kia Cadenza Premium Sedan (A51694)
2017 Kia Cadenza...
