How to test injections
   / How to test injections #1
Tractor 2021
Sa424
How to test the injections in the tractor
   / How to test injections #2
Injectors??? Suppose you take a minute and tell us what you are trying to do and why. Brand and model of tractor would help as well. welcome to TBN.
   / How to test injections #3
If your trying to narrow down a skip/miss..
Start the machine and get it skipping.. Loosen the nut AT THE INJECTOR.. it’s will start to leak as the pump rotated so it’s handy to have a rag..
Loosen and tighten the lines as u go down the line..
Your looking for the cyl that doesn’t make the engine lope..
   / How to test injections #4
Once u find the cyl/injector that’s suspect, u can move it to another cyl or hook it up OUTSIDE the engine..to watch the spray pattern..
BE VERY CAREFUL WHEN YOU DO THIS.!!! The SPRAY FROM THE TIP CAN AND WILL PENETRATE YOUR SKIN AND GIVE U BLOOD POISONING.!!!
No need to worry about it just loosening the lines..
UNLESS your working on a tier 4-5 engine..
UNUSED RAYSKY RM87-96 MOBILE TOILET (A54757)
UNUSED RAYSKY...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
