How to store your tractor question
   / How to store your tractor question #1
tdewit
OH
NH 1920
Just got my 1999 1920 today (Yeah!) but I have been seeing some questions regarding a stuck clutch. Now, in order to avoid that, how should I store my 1920 for prolonged periods? Store it with pushing the clutch in and hook it in the down position with the supplied link or just leave the clutch out in it's normal released position?
Tony
My 1920 is stored in a dry, concrete floor barn.
BTW, I read a lot of valuable info from other members here, one (soundguy) stating
"NH compacts used to come with small blocks of wood SPECIFICALLY for blocking the clutch when not in use for long periods. my 1997 NH 9120 had one .
I have some old fords that I block the clutch on.. my 2N and my 850.. both wioll get sticky if i don't... both work fine otherwise..
soundguy"
at
http://www.tractorbynet.com/forums/...r-been-sitting-clutch-will-2.html#post1385186
   / How to store your tractor question #2
well If SG says to block it, I would block it.
   / How to store your tractor question #3
Hey Soundguy should I block my 66 Ford 2000 with internal clutch pedal return spring if not used for extended periods?
I found a the mention small block of wood in the toolbox yesterday stating on it it's SPECIFICALLY for blocking the clutch when not in use for extended an period of time. It's about 3 inches long, and has a little diagram showing where to block it as well.
   / How to store your tractor question #5
Most tractors sit for 6-7 months every winter up here and i've heard a few old guys say they used to do it to vintage tractors but never actually known anyone do it, unless it's more of a problem in warmer areas .
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
SHOULE PWD-10 LOT NUMBER 133 (A53084)
SHOULE PWD-10 LOT...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
