How to start a ts1610
   / How to start a ts1610 #1
Mike4
Iseki ts1610
Hi I have just taken on a iseki ts1610 from a friend who inherited it when re bought his house and dose not know how to start it could anyone give some advice.
   / How to start a ts1610 #2
Simple.
Make Sure it is:
Out of Gear and is Netural
High Low Transmission is in Neutral
PTO is not engaged
Clutch is supressed
Switch is turned on
Fuel line isn't truned off
Battery is good and turns over engine
You are sitting in the seat.
That is all I can think of i once owned a TS2205.
This was what was needed to start mine.
Don
   / How to start a ts1610 #3
Turn key on
Turn black switch on left side of panel to the left and look down thru the hole right above the black switch.
when the coil is red, turn black switch to the right and it should crank right up
   / How to start a ts1610 #4
....and don't forget to make sure the air valve handle/rod is pushed in (forward) or you'll be cranking all day. Of course, this is the device that turns off the engine by blocking air to the intake. Located on the left side, outside of the control panel.
2000 Volvo VNL Truck, VIN # 4V4N21JF4YN250174 (A51572)
2000 Volvo VNL...
2022 Deere 317G (A50120)
2022 Deere 317G...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
