al3
Repairing a lift mechanism on an older Starcraft pop up. Need to replace an ovaled out bushing a shaft rests/rotates in. Passes thru the side of some thin 1/8 to 3/16 sheet. OEM bushing was steel, going to use an oiled bronze replacement. I'd called it a flanged bushing, think they also are known as bunting bearings.
At any rate, any good ideas on how to stake these? OD of replacement is just a tad undersized for a solid interference fit. My first thought is to put it in a 20 ton press and squeeze the hole a bit, but disassembling the rest of the thing would take some time. Second thought is to tack a small bead and press the bushing in; afraid that runs the risk of distorting the bronze.
Anyone pin the flange on one of these?
