How To Set Up Rear Hydraulics For Side To Side Movement On Backblade
   / How To Set Up Rear Hydraulics For Side To Side Movement On Backblade #1
drizler
Platinum Member
I致e had an old Dearborn 3 pt 7 blade forever using it for my snow removal. It痴 on my 1736 now and work it in conjunction with my loader . I have rear remotes and do have the CB 20 backhoe that痴 stored during winter. My plan add a hydraulic cyl so I cab angle the blade without constantly gettin on and off like a yo yo. I can fab and world the mounts easily but hydraulics aren稚 my strong suit .......yet. I知 planning on mounting the 2 spool valve up on the right fender on the raised plastic facia in that raised section with the 3 slits. I assume that痴 a knockout for things like this.
Ok I assume someone has already done this so SHOW ME THE SETUP:licking: Or tell me what goes where. I know I need a double acting cylinder 18-24 long with A1 minimum better 1.25 shaft.
While I’m at it on this thing I’ve got another question . Does the 1736 have an OPEN CENTER or CLOSED CENTER hydraulic setup? What’s the difference? As you can guess hydraulics isn’t my strong suit :confused3:
Case-IH 180 Magnum (A50120)
Case-IH 180 Magnum...
Kewanee Hog Cart (A50515)
Kewanee Hog Cart...
Kent KHB3G Q.A Hydraulic Breaker (A50121)
Kent KHB3G Q.A...
Ran during check in. No longer running. (A51694)
Ran during check...
2013 Volvo Semi Truck (NOT RUNNING)(TITLE) (A50774)
2013 Volvo Semi...
2017 Ford Explorer SUV (A50324)
2017 Ford Explorer...
