plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,394
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I have a irrigation water distribution box that needs replacing. But I'm not sure how to build a new one that seals tight?
The box is 4' square, 2' high walls. Existing walls/bottom use redwood 2x8's. The box sits sub-grade with only the top lid above grade. The old box is 50 years old, and was still working (with leaky patches) until a thirsty bear tore off the top and did it in.
I have located some 2x12" heart redwood ($$$$) which will allow fewer seams than 2x8's. A friend suggested using a Dado blade to create joints that can be glued and screwed. I'm guessing he means creating something like tongue and groove, or a lap joint. Not sure, as I've never used a Dado blade?
Do you have any suggestions, using Dado or otherwise, how to join the 2x12's so they are water tight? Sides, corners, and floor?
There are also wall penetrations for irrigation pipes. 2 1/2, 3, and 6 in. Any ideas on a simple method to penetrate wood walls with pvc pipe and have a good seal? (A 6" schedule 80 bulkhead adapter is $400+).
The box location is remote, with no power, and 250' up a very steep hill. I will probably have to haul up pieces and assemble the box in place. Concrete would be ideal-- except for access. I *might* be able to haul enough bags of concrete to pour one of the four walls, and have the pipes go through that wall? But then I would need a method to join the concrete to the wood side walls?
Any ideas?
Any ideas?
