how to replace drive belt on a NH 450 sickle bar mower?
   / how to replace drive belt on a NH 450 sickle bar mower? #1
keegs
Veteran Member
The County, ME
Kubota M5640SUD
I took my new old NH 450 out for a spin today and the belt broke. I'm pretty sure the part should be readily available but how to replace it doesn't look intuitive.
Has anyone replace a belt on the 450? Any tips on how it's done would be most appreciated.
Thanks!
Chris K.
   / how to replace drive belt on a NH 450 sickle bar mower? #2
Should be pretty simple.
Once you remove the belt guards, (if it still has them) there should be a tension bolt (jack bolt) on the drive pulley housing. Probably one or two lock bolts also.
Thanks Big...you're right.. to slacken or remove the belt I loosened the drive pulley mounting bolt. There's also a "tensioner" hook bolt with a threaded end that runs through an eyelet on the side of the drive pulley. The tensioner hook bolt nuts had to be loosened also. After slipping the new belt over the pulley and lightly tightening the drive pulley mounting bolt, I drew the belt tight by tightening the nuts on the tensioner then fully tightened down the mounting bolt. Piece of cake really.
John Deere TX 4x2 Utility Gator (A49346)
John Deere TX 4x2...
2006 Chevrolet Trailblazer SUV (A50860)
2006 Chevrolet...
2017 Ford Taurus SEL Sedan (A48082)
2017 Ford Taurus...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A48081)
2017 Mack GU713...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2025 K1428 UNUSED Traffic Cones (A50860)
2025 K1428 UNUSED...
