How To Replace A Starter Switch On A 861D 5 Speed
   / How To Replace A Starter Switch On A 861D 5 Speed #1
jtmcdon
Bronze Member
Oxford, GA
Ford/861D
A big thanks to Soundguy for helping me solve half of my starting problem, which was the solenoid.
Now I have to replace the starter switch. I've read I should start by putting the transmission in neutral. When I remove the transmission cover plate are there any springs or clips I need to look for? Also, does this tractor have a neutral saftey switch inside the transmission case?
Thanks. Tom
   / How To Replace A Starter Switch On A 861D 5 Speed #2
it's not a switch.. it's a mechanical interlink.
you can't press the thumb start switch if the shifter is not in one of the 3 N gates... same as the 4spd... has to be in N to press down...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
LOOK! (A53342)
LOOK! (A53342)
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
