Canopy How to Remove the TZ25DA Fender
   / How to Remove the TZ25DA Fender #1
JagAlfaOwner
Bronze Member
Roanoke, Virginia
New Holland TZ24DA
I was cleaning my TZ25 after mowing and found my Fender had cracked on the rear seat bolt going out toward the fender. I priced a fender and it is up to $1,250.00 plus shipping. I need to remove my fender and take to get welded. So before I take on this task I was wondering if anyone has documented the steps. I am due for my 600 hour service also so I have the fluids and filters to replace. My questions are:
1) Do I need to remove the Mid Mount mower?
2) Do I need to remove the rear wheels? Mine are filled with fluid so I prefer not to remove.
3) Do I need to put it on Jack Stands?
4) Any tips or tricks to help?
On a viewing it looks like it is encased in a Tub as I cannot get to the bolts from the rear.
Any information, suggestions, pictures or "Don't do what I did and" will be greatly appreciated. I know I need to remove my Canopy and ROPS, I see some bolts mounting the Fender to the Flooring. Other than that I will be working blind.
Al
Ok. I did it. it was easiest with he rear on Jack Stands. There were 6 bolts holfing the fender to the platform. Remove the ROPS seat (on a hinge) and tool box. Remove the handles and the 4 wheel lock handle. Mark the wires under the seat and rear and remove. Get someone to hold the handle and lift it up.
I had cracks the width of the bottom, around each Seat bolt running forward and sideways. It cost me $50.00 to have them welded and a cut sheet of metal the size if the seat bowl. The dealer had installed the New Holland patch and it lasted 12 years. I used it and the one that was cut sandwiched to the fender.
I hope it will not be a problem any more.
Al
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
6' Skid Steer Skeleton Bucket (A50515)
6' Skid Steer...
198832 (A51243)
198832 (A51243)
Bush Hog 287 3 pt Mower (A50514)
Bush Hog 287 3 pt...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
2006 FONTAINE TH55 SERIES 102" X 42' LOWBOY TRAILE (A51243)
2006 FONTAINE TH55...
