How to remove oil pan
/ How to remove oil pan #1
rickv3
chelmsford
1983 1710 ford compact 4x4 diesel
Hi guys, have a 1983 1710 ford compact tractor 4x4, developed a crack on side of engine above oil pan and suspect right to oil pan will attempt welding it but oil pan has to be removed. Does the front axle have to be removed or is there enough clearance to just remove oil pan ?
thanks
Rickv3
/ How to remove oil pan #2
Why did it crack? Best solve that problem before repairing. Sorry cant help re axle.
Jim
Tractor was lifted by front bumper too much stress on motor , will have it welded, its ok guys have the tractor seperated will weld inside and outside, thanks for the response.
rickv3
/ How to remove oil pan #4
Yup, I know about external stressors. Good luck with the welding. Make sure there's no oil or water passage in the weld area.
Jim
7051CFL (A64553)
7051CFL (A64553)
UNUSED FUTURE HLS82 HYD HORIZONTAL LOG SPLITTER (A65055)
UNUSED FUTURE...
2018 International WorkStar 7300 4x4 2,000 Gallon Water Truck (A64556)
2018 International...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
2022 EZ-GO ELITE...
DELTA TRUCK BOX TRUCKBED TOOL BOX (A65055)
DELTA TRUCK BOX...
