Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,950
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Been in house 3 years, last night I replaced both elements (only 1 bad) in water heater and found couple inches of calcium buildup in the bottom. I fabricated a scoop from 3/4 pvc by essentially cutting it in half lengthwise and scooped as much out as I could through that itty bitty hole. I had wondered why on earth it took FOREVER to drain /w3tcompact/icons/laugh.gif Now I know why, my drain is plugged.
Is there anything I can put in there to disolve the calcium and clean out my tank or should I just limp a bit longer and when I install a softner, just replace my water heater also?
I also had a dim light go off in my head (my ideas aren't always THAT bright in spite of my last name /w3tcompact/icons/laugh.gif) anyway, maybe take the old element (or search for equivilantly threaded aperatus) and take the center portion out. (don't ask me how). Attach a protrusion (again, don't ask me how) that can be attached to my shop vac. Screw attachment into bottom hole, turn shop vac on and flush with water while at same time sucking the junk into the vacume.
Maybe I should simply go to Walmart and buy the Water Heater Calcium Vacume Attachment for $7.99???
/w3tcompact/icons/smile.gif
