Hello, I'm not really sure of the correct terms to use for my problem other than what I have in the title. I've searched on the net and here and find nothing. I'm sure I'm not using the correct terms 'cause I can't be the only one with this little gem of a problem. :laughing:
Situation I have is we had our sprinkler system installed 5 years ago before our lawn was put in (hydroseeded). At that time the sprinkler heads were at ground level and all was good.
Now, years later, as the lawn has developed the sprinkler heads, when they are down (or not in use) are a good 2.5 inches below the surface of the grass. They barley clear the top of the grass when in use. I can see in the next year or so where they will not "pop up" far enough to clear the grass at all.
Question is, is there a way to "raise" the heads (without digging up the entire lawn
) so they are level again with the grass? I hope that makes sense. The wife has the camera right now but when she gets home I'll try to take a picture of a head or two to maybe give a better idea. I would have 78 heads to do.
The other question in the title is regarding how to find heads that no longer "pop up". I have one complete zone that no heads pop up when the timer gets to them. I assume the lawn has overgrown the heads because I can not see a one of the heads in the zone. I've tried walking the zone and sticking a metal rod down in the ground to try and "hit" a head but it's like finding a needle in a hay stack and I have yet to find even one. :mur: Any ideas on how to find a burried sprinkler head?
Thank you.
Thank you.
